2 members (RLB, 51 3804),
126
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | As winter approaches, it's getting too cold to paint in an unheated shop. I have a lot of small pieces that I could prep for paint, etc. in my large shop in the house. I can't really bring my compressor and paint gun there, so I'm wondering if anyone knows whether a good 2K primer is available in rattle cans that I could use to get these smaller parts ready for paint in the spring/summer. If so, do you have a product name? Is it available at NAPA, etc.? Will it be compatible with later paint applications? Thanks in advance for your answers.
Thanks!
Jim | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Hi Jim, I don't know if it a 2K primer, but I've painted all my parts with NAPA self etching prinmer. $4.99 a can, sprays great. Holds ANY paint on like glue, never EVER had a problem with it. Once I decided I wanted to changed a color of something I painted, I used my cab. blaster to remove the paint, but the ptimer stayed on for the most part. The only way to remove it is by wash/soaking in Laquer thinner. http://www.napaonline.com/MasterPag...scription=Spray+Paint+-+Specialty+Primer
| | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | Dear Modelman,
Thanks for the reply. I have also used self-etching primer on such occasions in the past and it seemed to do the trick. BUT, I have more recently read (I think on this forum) some posts from some expert body guys that you should never use self-etching primer for a good final paint job; your experience seems to contradict such advice. Not being an expert or very experienced in all of this, I would like to hear more from others who are the experts.
Thanks again!
Yours,
Jim | | |
