0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Right now I have my timing set to the flywheel mark with the octane selector at zero and the vacuum advance port plugged. To advance the timing would I use the octane selector? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim,
I would leave the octane selector at zero and add all the advance you think you want by loosening the holdown in the conventional manner.
Take your time and play with the timing until you get it to run exactly how you want. After you are satisfied you can fine tune it with the octane selector if you want.
This device is sort of handy, but with today's consistent gasoline, it's sort of a dinosaur from the bygone days. That's my take on it anyway.
Stuart | | |
