5 members (Cosmo, Otto Skorzeny, Bwana-Jim, J Lucas, Hotrod Lincoln), 98 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#334945 11/08/2007 11:20 PM
obtained a 216 all complete from a gentleman who was going to take motor to junk yard. It came out of a 1940 pick-up. My manifold on my 52'235 is cracked. Is the manifold off of the 216 interchangable? And what other parts can be interchangable? That motor last ran about 4 weeks ago.
Mike
1952 Chevrolet 2-Ton 6400
"Dempsey"
I think they will bolt up but I also think there is a difference in port size and perhaps spacing. Not sure if the 216 intake uses the rings or not. Since 235 manifolds are so easy to come by why would you use 216 parts?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Moneypit, For the sole reason that the engine was given to me free of charge and saw an opportunity to try to use what I had. I actually saved it from the junkyard. I was not sure if it could be used or not. Thanks for the input,I'm sure there will be many more questions along the way. If that is the case, I will continue the search for the 235 manifold.
Mike
"Dempsey"
Exhaust manifolds up to 1948 have a straight down exit, later ones angle back.
216s have a smaller intake port size and carb mount size but can be used.
My Blog
