| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33436 12/04/2004 1:24 AM | Joined: Dec 2004 Posts: 33 Apprentice | | Apprentice Joined: Dec 2004 Posts: 33 | I've been looking for a set of replacement wheels for my 8-lug truck for some time now. Has anyone found wheels that let you use the original style hubcaps? Thanks --Kyle
1953 3600 w/ full pressure 235 "Quando Omni Flunkus Moritati" --If all else fails, play dead.
#33437 12/04/2004 2:03 AM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I thought I had found a solution by purchasing some aftermarket wheels. I've been running into a lot of issues.
The wheels fit great with a 1/4" spacer but I would have to change the front wheel studs. Now that I've found the correct studs, the hubcap clips I ordered do not fit my 3/4 ton.
I'm to the point that I'm about ready to give up. The only option is to have Stockton Wheel take my hubs and weld them to a modern rim. The problem is they want $105 plus shipping for each rim. Seems like a lot.
Email me if you need more help. However, there doesn't appear to be a reasonable solution. Believe me...I've researched it pretty hard. | | |
#33438 12/04/2004 9:10 AM | Joined: Nov 2004 Posts: 13 Junior Member | | Junior Member Joined: Nov 2004 Posts: 13 | so I take Stockton wheel does not make a replacement wheel for a 3/4. I do not have the stock wheels and wanted that look. | | |
#33439 12/04/2004 1:47 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think Stockton wheel can make you rims with whatever offset you need. It is expensive, and I am not criticizing them because it take a lot of time, precision machining and somebody that really knows what they are doing. The hubcaps are another issue. Some owners use the white rims with the red stripe and spokes, that are made for trailers. I understand that the back spacing on those will work. | | |
#33440 12/04/2004 3:42 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Stockton can make wheels with the proper backspace but they do not appear to look original. They have the humps around the inner ridge to hold hubcaps on. | | |
#33441 12/04/2004 5:17 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Here's a post for what works for me. Maybe I just got lucky. My 16" 8-hole Rims. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#33442 12/04/2004 6:36 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have also seen an AD 3/4 Ton with new fancy alloy rims. They were either American Racing or American Eagle. I looked carefully and it had the standard front end on it. | | |
