4 members (Oswald, Otto Skorzeny, baldeagle, Aggie49), 81 guests, and 5 robots.
Topics128,021
Posts1,055,348
Members48,420
#33436 12/04/2004 1:24 AM
Apprentice
Apprentice
I've been looking for a set of replacement wheels for my 8-lug truck for some time now. Has anyone found wheels that let you use the original style hubcaps?
--Kyle
1953 3600 w/ full pressure 235
"Quando Omni Flunkus Moritati"
--If all else fails, play dead.
#33437 12/04/2004 2:03 AM
I thought I had found a solution by purchasing some aftermarket wheels. I've been running into a lot of issues.
The wheels fit great with a 1/4" spacer but I would have to change the front wheel studs. Now that I've found the correct studs, the hubcap clips I ordered do not fit my 3/4 ton.
I'm to the point that I'm about ready to give up. The only option is to have Stockton Wheel take my hubs and weld them to a modern rim. The problem is they want $105 plus shipping for each rim. Seems like a lot.
Email me if you need more help. However, there doesn't appear to be a reasonable solution. Believe me...I've researched it pretty hard.
#33438 12/04/2004 9:10 AM
Junior Member
Junior Member
so I take Stockton wheel does not make a replacement wheel for a 3/4. I do not have the stock wheels and wanted that look.
#33439 12/04/2004 1:47 PM
I think Stockton wheel can make you rims with whatever offset you need. It is expensive, and I am not criticizing them because it take a lot of time, precision machining and somebody that really knows what they are doing. The hubcaps are another issue. Some owners use the white rims with the red stripe and spokes, that are made for trailers. I understand that the back spacing on those will work.
1951 1 Ton Completed
#33440 12/04/2004 3:42 PM
Stockton can make wheels with the proper backspace but they do not appear to look original. They have the humps around the inner ridge to hold hubcaps on.
#33441 12/04/2004 5:17 PM
Here's a post for what works for me. Maybe I just got lucky.
My 16" 8-hole Rims.
#33442 12/04/2004 6:36 PM
I have also seen an AD 3/4 Ton with new fancy alloy rims. They were either American Racing or American Eagle. I looked carefully and it had the standard front end on it.
