8 members (Nick in Manitou, GMCJammer51, 68ironhead, Ridgeback, 66flea, 3B, KEVINSKI, 1 invisible), 99 guests, and 2 robots.
Topics128,169
Posts1,057,033
Members48,458
can some tel me where i can fine a webpage on the rear axle code or ratio is on my 63 pickup any help thanks alot
2 Offline
I think that the standard gear ratio for that year was a 3.90 if memory serves me correctly.
3.73, 3.07, and 4.11 are the listed options. There is a 3.90 listed as well, but I beleive that it may either be for the 4x4 option or possibly the Positrac option. The plant listed for the 3.90 is the Detroit gear and Axle (Eaton) instead of the Warren plant for the others (12 bolt).
Bill Burmeister
In half tons(C10),the 3.07 was the economy six option, 4.11 was usually used w/3 spd/OD, 3.73 is the most common. The code should be stamped on top of the pass side axle tube.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
hey thanks to all the answer i got i did fine a code stamp on it
it is hc1024n2
e this what i found not sure how to read it but that is what is stamp on it thanks again for the info
Comes up as a '65-'66 3.73 axle according to my info. Perhaps it's been changed by a po?
Bill Burmeister
hey thanks for the info is there a web page u fine this at ?? sounds like a good highway gear .thanks again
I've got a spec book handy that I look it up in.
Bill Burmeister
thanks longbox55 i have a extra rearend in the shop when i fine time i,ll look it up and send it to u if that is ok thanks u sir for your help.guess i need a book like that
It's the Catalog of Chevy truck ID Numbers, 1946-1972. Published by Cars&Parts. It is still in print. I got mine from WaldenBooks. It's alright by me if you can get the codes, I can break them down for ya!
Bill Burmeister
ok cool that be nice sure thank u for the help u gave
