8 members (Barney1951, Bill Hanlon, BC59, 55shaker, JW51, JoergK., lumbersawyer, 1 invisible),
38
Mod | | | Forums66 Topics128,176 Posts1,057,121 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Here is the dilema: My 3100 is completely dissassembled, less stock driveline, suspension, etc 3100 Album I can re-bolt everything that I have together, however I do not have original driveline or suspension. On the flip-side I believe that someone out there has the answers I need I am in process of building an IFS front X-member that I would like to work with minimal sheet metal interference as well as with both an I6, or V8(in the event I chose to make more than one and offer to the general public). Anyone have a pile of pictures and dimensions of an AD without motor and with the front sheet metal in place, or better yet, anyone near enough to green bay for me to visit? I need to know how high above the frame that the stock fenders come. What will need to be trimmed to accommodate the upper a-arms. I also need to know where the stock engine, engine mounts, steering, and front suspension sits (which I do not have). I do have the CL location from front of the frame. Scott
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Yet more questions - cleaning my rad support, there is damage from prior owner disassembling with a gas axe Rad Supt 1 rad supt 2 Rad Supt 3 rad supt 4 The questions related to this part only: 1.) Is/was there a weld nut on the back side? 2.) does someone have a view of a non damaged rad support? 3.) is the top edge bent? 4.) Anyone have a non-busticated one for cheep? Scott
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Scott, get a factory Assembly Manual. I saw 4 or 5 on Ebay for 25.00/30.00 the other day. You will really need one soon if not now.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I have a manual coming should be here any day, however still looking for an answer or two.
Scott
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Scott my rad support is at the body shop and I'm waiting for my camera's battery to recharge. I'll go over and take a few close up shots for you today or tomorrow if you still need it.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Thanks, yes I do. FYI - acid bath works wonders.  soaked for two days and hit with pressure washer. support looks good except the two torched holes and a missing pressed in nut retainer. Does anyone know if these are available, or should I go with welding in a washer and weld-nut? :confused: Scott
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I will post pics tomorrow.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Thanks. I PM'd you my email if you would rather send
Scott
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | My guess this is bent? Rad Frame 1 rad frame 2 Anyone have a view from this angle?
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Another question about my '48 Half-ton. Truck has the below box fuel tank. I am currently trying to salvage the fuel tank because I can not find anyone who makes these.
Am I missing a vendor? Wend through the LMC catalog, Brothers web site, Chev's of the 40's. All have the in-cab tank, however can not find the bellow box version.
Should I keep trying to restore this one, or should I just buy a fuel cell?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I think the behind the seat fuel tank was the standard issue for the 3100. Do you know if the PO converted to the tank you have. There are previous threads that discuss this topic.
Drew
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | No, the tank is original for the '47 and '48 year half tons, I can find pictures, etc showing the tank on vendors web sites, just no one has the tank.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I had planned on an aux tank in the rear and bought a Blazer tank which is 1/2 too wide. I have given up and will be ordering an aluminum custom built tank from Alumiworx. http://www.alumiworx.com/cart/index.php?act=viewDoc&docId=2
~Jim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Panels and Suburbans used that same under the bed tank all the way through '55 1st. I don't think you'll find one in a catalog, but knowing the broader usuage might help you find a good used one.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | At nearly $700, I am thinking I try my hand at continuing to restore this one with the POR15 kit, if not, I can go the custom route or a fuel cell. The inside looks ok, a little varnishy, however the outside is rusted. The acid bath is running a little slow now that the temps are in the 30's. I picked up a stock tank heater to keep the thing from freezing tonight.
someone remind me again why I still live in Wisconsin
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | DANG! I think it's something like 72 degrees outside here.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Rub it in Jim, rub it in....
Thanks for the pics on the Rad support. Would you have one of the inner fenders installed?
Scott
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Anyone have luck pounding out dents out of a grill
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Scott: Take it to a chrome plating outfit. They do that sort of thing.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The dulled chrome is fine for my plans for now, I was looking for suggestions from people who have successfully straightened these themselves without leaving hammer marks.
Plus if I succumb to a case of shipfitters disease, then the truck will never be rolling in time.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | OK, so I have my shop manual...Nice looking fresh re-print. Not much help for my needs. While it tells me the sequence of removing items, it is a little light on exploded views.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the assembly manual has nothing but exploded views Bill | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Ok, so does anyone need a shop manual?
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Keep it. It is good for repairing stuff later on giving the steps needed to get the job done. It has some uses but for me the assembly manual is more useful. I thought you had one coming.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Turns out I purchased the Shop manual vs the [censored]embly Manual.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Ok, so does anyone need a shop manual? Yes, you do. And it also won't hurt to have a Motors Truck Repair Manual covering your year. You can't have too much info. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Another Question on my '48.
I will be getting a custom rad made up, however I am also sectioning my cab 2.5". How much room between top of stock radiator / hood latch plate and the stock hood as the sectioned area will be coming out of the hood in the front.
Scott
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Scott I'd post this over at the paint and body or hi po. You'd get better responses there.
~Jim
