| | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Hi guys, after contemplating my route w/ my newly acquired '50 1/2 five window shortbed project...I'm thinking of leaving the fram original, but would like to upgrade the rearend and scrap the torque tube. I'm planning to run a 327 small block backed by a th350 trans. Any thoughts on a rear end that has the same length would be very helpful. I don't need/want posi, but would like to run 3.55:1 gears. Thanks! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | By Trail Blazer, do you mean the S10 or the newer TrailBlazer/Envoy? The later (6 lug) TrailBlazer axle is a bit wider than the S10, and the bolt pattern is not the same as the older trucks, so the wheels will not work on it.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Thanks for the info on wheels...that was one of the questions I had yet to answer...
I was thinking about 2002 to present Trailblazer/Envoy. I did a quick measure at the boneyard, but nothing technical. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The bolt pattern is metric, comes out to just a bit over 5", rather than the 6 x 5 1/2" like the older 6 lug trucks. Wheel options for that pattern are somewhat slim, or at least anything that would look right on a 'Bolt. The Colorado/Canyon has the same axle.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | A 10 bolt Camaro bolted right up to mine. BTW if you plan on any highway driving you might want to run an auto with overdrive.
~Jim
| | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Thanks for the replys. I'll shop around for a Camaro 10 bolt. Any specific years? Did you convert the front of your to 5 lug? Or could the Camaro axles be drilled to the correct 6 lug pattern? Yeah, I hear ya on the overdrive...I have a '68 SS Camaro w/ a th350 and 3:73s. Sure screams at 65 mph:-) Thanks again! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Nope! I installed a Heidt's Mustang II IFS which is 5 lug disk. You might also look for a 95 Firebird rear. It will fit like the Camaro but will come with disc brakes. Also if you do get a Camaro 10 bolt you will find that the 2002 Firebird disc brakes will bolt right up to the Camaro axles.
~Jim
