5 members (TUTS 59, 32Fordpuchoptop, panel fan, UtahYork, Otto Skorzeny), 68 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#333313 11/05/2007 4:49 PM
Hi guys,
after contemplating my route w/ my newly acquired '50 1/2 five window shortbed project...I'm thinking of leaving the fram original, but would like to upgrade the rearend and scrap the torque tube. I'm planning to run a 327 small block backed by a th350 trans. Any thoughts on a rear end that has the same length would be very helpful. I don't need/want posi, but would like to run 3.55:1 gears. Thanks!
http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
Check the link above for some basic info...I am checking into using a Chev Trail Blazer rear end with 3:42s and rear disc brakes.
By Trail Blazer, do you mean the S10 or the newer TrailBlazer/Envoy? The later (6 lug) TrailBlazer axle is a bit wider than the S10, and the bolt pattern is not the same as the older trucks, so the wheels will not work on it.
Bill Burmeister
Thanks for the info on wheels...that was one of the questions I had yet to answer...
I was thinking about 2002 to present Trailblazer/Envoy. I did a quick measure at the boneyard, but nothing technical.
The bolt pattern is metric, comes out to just a bit over 5", rather than the 6 x 5 1/2" like the older 6 lug trucks. Wheel options for that pattern are somewhat slim, or at least anything that would look right on a 'Bolt. The Colorado/Canyon has the same axle.
Bill Burmeister
A 10 bolt Camaro bolted right up to mine. BTW if you plan on any highway driving you might want to run an auto with overdrive.
~Jim
Thanks for the replys. I'll shop around for a Camaro 10 bolt. Any specific years? Did you convert the front of your to 5 lug? Or could the Camaro axles be drilled to the correct 6 lug pattern? Yeah, I hear ya on the overdrive...I have a '68 SS Camaro w/ a th350 and 3:73s. Sure screams at 65 mph:-) Thanks again!
nastbscott #333538 11/06/2007 12:06 AM
Nope! I installed a Heidt's Mustang II IFS which is 5 lug disk. You might also look for a 95 Firebird rear. It will fit like the Camaro but will come with disc brakes. Also if you do get a Camaro 10 bolt you will find that the 2002 Firebird disc brakes will bolt right up to the Camaro axles.
~Jim
