| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | My dad bought me this sander today. http://www.mytscstore.com/detail.as...sonID=463&page=1&productID=28867I was wondering what kind of sanding disks I should use.
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Any store that sells body filler should be able to set you up. That sander looks like it takes a grinder disk so don't plan on doing any finish sanding with it.
| | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it is a grinder as it appears 400 is way too fine. A grinder is for taking lots of material off quickly so 24 or 36 grit is what I'd recommend. A DA or orbital palm sander would use 400 grit OK.
| | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | Thanks I got it to remove paint and bondo
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 36 will be fine, or maybe 60 if you can find it. Oh, and wear a mask and eye protection. Those things really throw up the dust.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jarred, I have on of those sanders. I will say this..even with a 36 grit disc it seems like it doesn't take too long before the horrendous RPM of this unit starts to smear and burn the paint as opposed to remove it. Maybe I just have 'gooey paint'.  Stuart | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's one of the major drawbacks to an air grinder, too many RPM & not enough torque to operate well as lower speeds. I'll take an electric grinder any day.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'd have to agree with ya 100% Tiny. I've got one and it makes a better HS drill than sander. I was doing some grinding the other day with a little angle grinder I bought at HF and listening to the 3hp motor hammering away when this thought occurred to me. Wouldn't it be a lot more energy efficient to use one of the 4" electric angle grinders that only draw 5amps on 120v instead of pulling 12amps at 240v to do the same job? The electric grinder is powering a larger disk and like Tiny says, it has more torque. So what is the advantage of using air over electric in the first place??? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Those 5-inch grinders are good for things like edge clean up prior to welding, shaping the edge of sheetmetal when fabricating and other small jobs. They're not very good for other things for the reasons already mentioned.
If you have large areas of paint to remove you either need a larger disk spinning slower or a chemical paint stripper. | | |
