8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna), 154 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
My dad bought me this sander today.
http://www.mytscstore.com/detail.as...sonID=463&page=1&productID=28867
I was wondering what kind of sanding disks I should use.
Now boltless but looking
1951 F-1 350/350
1965 Mustang 355 glide
1971 F-100 401 fe it hates me
1972 Maverick 302 c4
Ex Hall Monitor
Ex Hall Monitor
Any store that sells body filler should be able to set you up. That sander looks like it takes a grinder disk so don't plan on doing any finish sanding with it.
400
Ex Hall Monitor
Ex Hall Monitor
If it is a grinder as it appears 400 is way too fine. A grinder is for taking lots of material off quickly so 24 or 36 grit is what I'd recommend. A DA or orbital palm sander would use 400 grit OK.
Thanks I got it to remove paint and bondo
1951 F-1 350/350
36 will be fine, or maybe 60 if you can find it. Oh, and wear a mask and eye protection. Those things really throw up the dust.
Bill Burmeister
Jarred,
I have on of those sanders. I will say this..even with a 36 grit disc it seems like it doesn't take too long before the horrendous RPM of this unit starts to smear and burn the paint as opposed to remove it. Maybe I just have 'gooey paint'. smile
Stuart
Ex Hall Monitor
Ex Hall Monitor
That's one of the major drawbacks to an air grinder, too many RPM & not enough torque to operate well as lower speeds. I'll take an electric grinder any day.
I'd have to agree with ya 100% Tiny. I've got one and it makes a better HS drill than sander.
I was doing some grinding the other day with a little angle grinder I bought at HF and listening to the 3hp motor hammering away when this thought occurred to me. Wouldn't it be a lot more energy efficient to use one of the 4" electric angle grinders that only draw 5amps on 120v instead of pulling 12amps at 240v to do the same job? The electric grinder is powering a larger disk and like Tiny says, it has more torque.
So what is the advantage of using air over electric in the first place???
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Those 5-inch grinders are good for things like edge clean up prior to welding, shaping the edge of sheetmetal when fabricating and other small jobs. They're not very good for other things for the reasons already mentioned.
If you have large areas of paint to remove you either need a larger disk spinning slower or a chemical paint stripper.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Moderated by  MNSmith
