2 members (KEVINSKI, JW51),
79
Mod | | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 10 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 10 | I'm looking at buying a GMC panel truck but I can't find the year. Web sites show it at as a 60's when it clearly is a 48-53 model by the looks of the grill. The number on the plate at the door is 253 22 P 6264. Owner is trying to come up with the paperwork. HELP! TY in advance. Jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 253 = 137" 1 ton (250 series)
22 = 228 cubic inch engine
P = Pontiac Michigan Assembly Plant
6264 = production number = 5264 (or, maybe 5263)
I think the year is 1951
| | | | | Joined: Oct 2007 Posts: 10 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 10 | Hello
TY for the info I had some of it figured, such as the engine, I thought the P stood for Panel. The S/N still confuses me. According to the site I found the 6264 # puts it as a 51 but it looks like the 253 was not made until 52? How did you come with the 5264 #? Jim, Lassentrucks. Have the bolt in the yard, should be getting pictures up in the gallery soon. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | GMC Serial Numbers - oldGMCtrucks.com The table shows that the 252-22 (125 1/4") & 253-22 (137 1/2") GMC trucks were made from 1951-1953. The serial numbers are in the right column. The serial numbers started at 1001, for each series. So, the first truck/chassis? off the line for the 252-23 series was number 1001, and the first truck/chassis? off the line for the 252-22 series also started at 1001 (as I stated above, I think this is how the information in the table is interpreted). My opinion is simply an interpretation of the pages out of a GMC Master Parts Book. It you want a more knowledgeable answer, go to the oldGMCtrucks discussion board. Tim | | | | | Joined: Oct 2007 Posts: 10 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 10 | Hello, OK I admit it, I'm slow at times. But I get it now. TY. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You're not slow. I had to read it about 5 times and every time I read it I interpret it in a different way. | | |
