5 members (Otto Skorzeny, Jay R, carbking, Gdads51, mick53), 96 guests, and 2 robots.
Topics128,259
Posts1,058,298
Members48,485
#332585 11/03/2007 9:28 PM
Finally have gotten my 56 running enough for a test drive. It has a 79 Camaro frontend grafted on it with PS, PDB, Fresh Professionally rebuilt 350 SBC with Comp Cams 280H cam, Headers, Camaro 3.79 rearend, 95 Suburban seats,New Southern Air A/C, Tilt Column from 76 Chevy Pickup, new driveshaft, battery, MSD HEI Distributor, alternator, etc. etc. ad nauseum!! Still looks rough on the outside, and I am not happy with the idle (may be the 85 Quadrajet that is on it right now. Brakes need some work, but all in all, minor issues. Problem is, I did not realize how low this truck sits. I have built this to be an everyday work truck that I could also use on the farm. I did not do the frontend graft. Bought it already done. So now I'm wondering how I can increase the ground clearance without major rework. I'm getting to the point where I am thinking maybe I should just sell this one and get a 60's or early 70's Chevy that is closer to stock ride height. Opinions? Anyone want to trade? I am at that point!
Clint, Hello from Idaho. I put a Camaro clip under my first 52 Chev. When I let in off the jack she hit the floor and stayed there, toooo low for rural Idaho. A friend told me there were several different wieghts of springs available for that front end. I installed a set of "big block" springs and raised the truck a good 3-4 inches. Turns out I had springs for a 6 banger. That might help. Good luck, Boltbuster.
45 Chev 1/2-ton (what's left)
Apprentice
Apprentice
Boltbuster,
Where did you get the big-block springs? How do I know which ones I already have? Are there any specs on them as far as measurements to determine what I have?
Thanks, Carl
CCB
