2 members (Gib70, Tronman), 117 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#332502 11/03/2007 5:36 PM
I'm replacing the spring shackles and bushings on my 52 GMC 1/2-ton. I have a set of bushings that someone gave me, there are 4 steel ones that are threaded for the shackle pins, then there are 2 brass ones that are not threaded but have grooves on the inside, for grease I guess. When I took my springs off, the eye bolt hole has the same steel bushings as on the shackle end. I'm thinking I should use the brass bushings on the eye bolt hole. Anyone know if that's right? And also, is the spring symmetrical (looks to be), do I need to keep track of which end is the front or does it matter?
Mike
Do keep track of the ends, springs are usually longer from center bolt to front or back, I forget what way is the usual offset though.
The bronze bushing will usually go in the spring eye it's self, the opposite end of the shackle, as the shackles are the threaded type.
The service manual will help a lot with these types of questions.
Please correct me if this info is wrong for 1/2 tons, I speak from experience with the bigger trucks only.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #332640 11/03/2007 11:25 PM
Thanks Grigg, I have a Service Manual and an Assembly Manual, and neither says anything about the bushings.
