3 members (Otto Skorzeny, MNSmith, tclederman), 73 guests, and 1 robot.
Topics128,052
Posts1,055,718
#331712 11/01/2007 10:48 PM
I'm getting ready to remove the cab off of my 51 GMC this weekend, would appreciate all the advice I can get!
southerncharm #331713 11/01/2007 10:56 PM
4 friends or an engine hoist should get it done. If you have the cab stripped down, it should not be too bad of a job. I did my 46 by myself..both off and back on.
46 In Progress #331716 11/01/2007 11:12 PM
I have a tractor with a front endloader attachment. I was thinking about running a strap through the cab and around the roof and just picking it up. I pulled the pittman arm off yesterday and took the bolts out of the steering box. Pedals are off...... can't see anything else that needs to be released other than the temp guage wire , speedometer cable ... few minor things.
southerncharm #331737 11/02/2007 12:09 AM
I used a strap and a winch truck and ruined the stainless trim around the doors. Remove the doors or the trim before you do it that way.
Cletis #331744 11/02/2007 12:30 AM
I use a cherry picker and a 2 x 6 to lift of the cab
cab lifting
Scott
Three of my girlfriends and myself lifted my 54 cab off. It was a little difficult for us but we managed safely.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Samantha #331952 11/02/2007 11:20 AM
I completely gutted the cab and a neighbor and myself were able to lift it off the frame without any trouble.
mummdogg #331954 11/02/2007 11:55 AM
I would definitely suggest removing the steering column completely before attempting to remove the cab.
1951 1 Ton Completed
truckernix #332016 11/02/2007 2:59 PM
When you think you've removed everything, look again. Don't forget the gas line, emer brake and the ceiling of your garage.
~Jim
Tractor with a loader, four guys, cherry picker inside, I've seen each of these work.
Make sure you stop and check for things not yet disconnected as you go. The wire for the fuel gauge is tougher than you might think. The emergency brake stuff can cause trouble too.
Good luck!
OldSub #332386 11/03/2007 5:52 AM
I just used a couple of planks prpped up on cinder blocks lifted each side until I could roll the frame out from underneath...
GMC: Get More Cash...
1958 GMC
My Webshots photos
