| | | Forums66 Topics128,037 Posts1,055,580 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | Well, my night in the shop ended earlier than I expected. I was removing flywheel from a 216 and 5 bolts were no problem but rounded off 6th. My question is, can anyone tell me if the Craftsman Bolt-off will work on a bolt with this much torque? I,ve never used them but will get set tomorrow if I'm not wasting my money.
Thanks, Rex
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rex,
I have never used this item so I can't answer your question...but, I have used a metric socket sometimes to remove a ruined non-metric bolt. If you can find a 6 pt metric socket that is a hammer fit on your rounded flywheel bolt, you might have another chance to get it off. Cross your fingers.
Stuart | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Rex Depending on how bad it is rounded off,you might try a 6 point socket. This often has worked for me, if you haven't tried it allready. I have never used the Bolt off, but it might be worth a try. Good luck Jim | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I bought a set of the Craftsman sockets and they are worth the price. Just think of the rectal irritation you'll encounter before you bite the bullet. Makes the price seem a lot easier to endure. Tramp | | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | Thanks guys for the advise. I'll try it. Rex | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Try putting the other bolts back in,,it'll take some of the pressure off the one bolt youre struggling with. Marty | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Try a new Mac or Snap On flank drive socket...I have had these sockets remove a rounded nut that cheaper sockets won't touch... Also the Craftsman Bolt off's work well. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It's too late now, but be careful when you are removing flywheel bolts. Since the heads are thinner than normal, you need to use sockets that don't have much of a chamfer or fillet before the flats inside. I have a socket that I ground down so it would grip more of the head to avoid ruining flywheel bolts.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now that, is a good tip J! Denny G
Denny G Sandwich, IL
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I would first smack it straight on with a brass punch and hammer to shock it. I would then buy or borrow a Gator Grip socket.I have been in shock over how well they grip.I have never used a Craftsman bolt-off, so I can't say if they work or not. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Since the bolt is junk already, use a 6-point socket, and heat the bolt almost red hot with an acetyline torch before applying the socket. The bolt will stretch, relieving the torque, and it will spin right out with little effort. Jerry
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | And if that doesn't work weld a nut on top of it.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | If you started with a 12pt socket that's where you problem began they have less grip surface for the head of the bolt and tend to slip and ruin the head try a 6pt it will give you more grip and as Marty noted above put the others back in don't need to torque but tight to take the strain off of the bad one.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Sears Craftsman has some sockets that can be hammered over a rounded off bolt to make a force fit. The socket has serrations inside to bite into the bolt head. They work great.
34 & 35 trucks are the greatest
| | | | | Joined: Aug 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 37 | Before you drive a socket on the bolt, try heating the bolt til it turns red. Then quench it with either ice or co2. This expands the bolt then shrinks it as well as cracks any rust. This old trick that my dad taught me about 40 years ago has never failed me. Also the parts stores (Auto Value/Bumper to Bumper) has a spray that not only lubricates but also freezes the bolt thus cracking any rust and this works great. If this fails, grind the head of the bolt off and remove the flywheel. You might be able to weld a nut on the bolt and back it out. Just my $.02 worth. Don
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
| | | | | Joined: Aug 2007 Posts: 33 Apprentice | | Apprentice Joined: Aug 2007 Posts: 33 | I agree. I would replace the other bolts to take the pressure off of the bastard one.(There's always one,huh) Then if you can get a socket that you have to hammer (not beat)on tap the back of your ratchet/breaker bar while applying torque slow, but steady. I work in a tool and die shop and have seen this work. Also you might remove it by "WALKING" it out with a VERY good pin [censored] chisel,, depends on the torque. As I'm sure you know, the key word here is finesse. Good Luck!!!! Terry1218 | | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | Thanks to all that replied. The boltoff worked great and when I reinstal I will use the tip about grinding the very end off of a socket which makes alot of since.
Rex | | |
