2 members (BC59, Uncles51),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 | Just got this email from one of our Bolters who hasn't had his registration approved yet, but needs your help.
Just purchased (from original owner) what is titled as a 1942 Chevy pickup. VIN # ABF45145 I can’t seem to find any info on the actual year for this truck or what it is. I tried the VIN decoder, but no luck. There are no numbers before the ABF on the title. I have not been able to get at the vehicle to check data plates.
Any Idea on this Vin #??
Thanks, Kenny
His registration should be approved when Paul gets a break. But he'll check here for your responses / questions. Thanks ~ Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Kenny, Try the links section.. you are looking for Brad's 41-46 pages in the trucks section..There is a section on Brad's site about VINS for our trucks. Also check the post on here for a VIN question on a 45. I posted the link to the page on that post. 42s and 45s are numbered the same. The A is what is throwing you off. http://www.brads41-46chevys.com/id14.html
| | | | | Joined: Oct 2007 Posts: 1 New Guy | | New Guy Joined: Oct 2007 Posts: 1 | Ok I must be completely lost. I looked at the VIn site and even tried the Vin Buster. I could not locate any combination of ABF for the first part of any of the Vin #'s.
ABF45145 Can anyone help?
Good to be here. I will get pictures as soon as I remove the truck from the tree....... | | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | I just bought my 42 1/2ton, title says GCM17687, I can't find any information either, if you find something, please let me know. Thanks cdroberts | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That number will probably be on the engine instead of the data plate. Look on the boss behind the distributor. You may have to scrape off some grease. The data plate will have your serial number which usually was not the VIN until 1956.
| | | | | Joined: Nov 2004 Posts: 2,401 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,401 | Just a thought, my '42 has the original 216 engine with same number of characters as your (VIN). I too, think that your title number may reflect the engine serial number that is normally found right behind the distributor.
It's very possible after all these years, that your truck might even have a different engine. The first three digits on my engine are BF4, I suggest that you look carefully at your ID tag on the cowl. I had to use a magnifying glass, and even rubbed a bar of soap on another to get the numbers right. Sometimes a flashlight shined at an angle can make numbers and letters more readable.
Good Luck
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 70 | not sure about the 42 but the id number on 37s is also stamped on passenger frame rail just over the front axle/ leaf spring .i had to wire brush my frame to be able to read the numbers there. the PO IN my case used a id number off the motor and not the real id number for some reason. if anyone has a copy of a 1937 Branhams automoblie referance book you may find a better explaination there it will tell you how many were made cost what models there were etc. hope that helps Earl | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | the PO IN my case used a id number off the motor and not the real id number for some reason. Earl Most states used the engine number through 55. States using the serial number were the exception rather than the rule. The hassle of re-titling after an engine change is probably the main reason the practice was stopped.
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | GMC1937, that must be a GMC thing, being stamped on the frame, Chevrolet didn't start that till 1955. My '37 didn't have any numbers except the cowl tag. The title showed the engine ID number but wasn't anything close to the cowl tag number. I always thought they used engine ID's on the title, that would explain the VIN not matching any of the web based VIN decoders. Joe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | GMC1937, that must be a GMC thing, being stamped on the frame, .... Yep, that was a GMC only thing. | | |
