7 members (55shaker, 1955 1 Series, Bill Hanlon, Oswald, Greg_H, Ponchogl, Shade Baby),
140
Mod | | | Forums66 Topics128,261 Posts1,058,345 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33164 10/30/2003 3:45 PM | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | I want to have the front drums sandblasted so I can por-15 them afterwards but concerned about hurting the threads of the wheel bolts. Is it hard to remove the bolt assembly from the drum? Also, will this assembly need to be put back in before I have the drums turned?
Is it wise to sand blast, paint and then turn the drums, or turn, sand & then paint?
Living in America,,,,,so many choices
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#33165 10/30/2003 8:51 PM | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | I just discovered that 2 out of 3 rivet that holds the lugbolt assembly to one of the drums is missing. Does anyone know who sells these ?
#33166 10/30/2003 11:32 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | If the drums aren't scored badly or out of round I wouldn't have them turned. Just have them checked to make sure they're in tolerance and then scuff them with some sandpaper. Don't worry about sandblasting the studs. It won't hurt them. Like Metal Man says,why Por-15 if you sandblast. Just clean and paint.Rust-O-Leum would work fine on a budget with the clean drums.
Can't help with the rivets,maybe the shop where you took the axle can help. | | |
#33167 10/31/2003 5:07 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can buy steel rivets at the hardware store. Sandblasting does remove and deform metal. I would find some cheap hose that fits snugly over the threads. We use bead blasting to improve threads, but sandblasting is to hard to control.
Fred 52 3600 69 C-10
#33168 11/09/2003 4:51 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Hope you keep us posted on this... With so much disassembly (TWO front ends!) what is your preference for penentrating oil? Did you break anything? | | |
#33169 11/09/2003 5:00 PM | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | One drum is still riveting to the hub. The other was deriveted by previous owner. Guess what the de-riveted drum is warped and cannot be turned. The other drum turned perfectly. Thus I've ordered another drum/hub set from one of our favorite fellow bolters in Az for a very good price.
Lots of GUNK penentration oil and paitence. Nothing broke yet, but keep in mind, I haven't removed my '50 assembly from the truck yet. Those spring U bolts look like a challenge.
Rainy day today. Good day to spend on this project.
#33170 11/09/2003 6:21 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | If it were me, I would take a Sawzall to those old spring U bolts . Replacements are cheap.
You will be able to trust the threads on the new ones to hold tightly..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#33171 11/10/2003 4:30 AM | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | Good point, It would be a lot easier to not be forced to cleaning up old threaded bolt ends, etc, when the replacement are readily available.
