1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#331192 10/31/2007 8:41 PM
On occasion at idle I get what sounds like a slight knock coming from my voltage regulator. With each knock my voltmeter/ammeter needle jumps a bit. 12 volt system with stock wiring.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Riding in the Passing Lane
It,s probably idleing at a point where the cutout is going in & out. Set the idle up a little faster.
1972 Chevy c10 Cheyenne Super
Bill,
Wrenchbenders idea makes perfect sense, but I find it incredible that you could hear a dinky set of points clicking shut from the drivers seat.
Many voltage regualtors are mounted on three little rubber feet which would further insulate it from the firewall. You must have 'super hearing'... grin
Stuart
Stuart
I have been known to have great hearing but even a deaf person could hear this. Way back when it started I thought it was an engine knock until I opened the hood and heard it coming from the regulator. And as I said the needle jumps with each knock. Again this happens on occasion, not all the time even at idle. Apart from that there is no problem with the electrics.
I will notch up the RPMs a tad however.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Hey blue if you need a used voltage regualtor drop me a line and it is yours
Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
Peter thanks. I think mine just needs adjusting and I'm hoping to get more input here. Someone old me to file the points using the striker band on a pack of matches. We'll see.
I was by your place 2 days ago, saw the GMC in the drive and the big Olson with the tarp on it. Didn't want to drop in unannounced.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
