1 members (Uncles51), 105 guests, and 4 robots.
Topics128,028
Posts1,055,414
Members48,422
#127923 08/31/2007 1:57 AM
ohwell
Can someone tell me where/how I can find paint by the code? The blue on my 57 is in far condition and with the dash plate I just welded in I’d like to spray the original color over the primed area.
The long and short of it,
Paint Code - GM-3878 with clear 3701
The only reason I know this is the PO left a touch up (plasti-kote) bottle in a box of stuff that can with the truck. I tested it, and it’s a perfect match.
Appreciate your help or suggestions.
HC
ohwell
57' Chevy 3100 Stepside
http://www.cardomain.com/ride/2630531
bump
might check a shop that sells lots of paint to body shops and see if they've got a stack of chip books to look thru, or some big box place that has lots of plastikote touch up paint, obviously a 'modern' color
Authorized Pest
Authorized Pest
P Online: Content
Here\'s a good read on painting, too. John and I were just talking about this Tech Tip yesterday.
Peg
~ Peggy M
1949 Chevrolet 3804
Thanks Peggy, Red
That's what I was afraid of. I was really hoping to be able to order it on-line.
I'll start calling around. I'll post back here to let everyone know what I find.
thanks again,
HC
HC-
I did a search for that Plasti-Cote part number and it coincided with a 1993 GM color of WA9544 which is a Medium Quasar Blue Metallic base coat/clearcoat. You should be able to use the GM code of WA9544 to get paint at any automotive paint store.
Jeff
guthriesmith,
MAN - LET ME BUY YOU A BEER!!!!
That's awesome that you were able to find that! I was searching and searching. . I don't know how you did it (care to share the secret?).
Plasti-kote didn't hit on there own product number through any search. But as soon as I drilled down with your numbers and the year, BANG! There it is.
Plasti-Kote WA9544/80 GM 7217* GM 3878* MEDIUM QUASAR BLUE M B/C
I can't thank you enough.
HC,
To be honest, if I would have looked at the picture of your truck first, I probabably could have guessed it (I had a 91 Corvette that color). However, I just scrolled through each year on the Plasti-Kote site for GM colors until I found the GM 3878 number. Maybe not the most efficient way, but it worked. Glad to be able to help. I aquired somewhat of a passion for matching colors when I was a custom painter and frequently had to match colors that no one had documented at all.
Jeff
Well thanks again Jeff.
It was like Christmas morning when I read your response smile
Well now that you have Jim taken care of Jeff, maybe you can steer me in the right direction. I spent about 45 mins at Plasi-kote lookin for a paint number for the "New Ford Gray" engine enamel but it won't return anything, just no page found errors. The gray looks very close to the early AD 216 factory gray. I'd like to pick up a can and compare it to what I'm using.
Wonder if ya can help me out?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny,
It looks like Plasti-Kote has two gray engine enamels which are "Universal Gray" and "New Ford Gray" as follows:
ENGINE ENAMEL
END ITEM CODE PART # DESCRIPTION UPC
400.0000202.076 202 Universal Gray 0-71915-00202-1
400.0000216.076 216 New Ford Gray 0-71915-00216-8
On the web site, they appear to be close in color to each other. Here is a link to the information page and color sample page (if they work).
Info page:
http://www.plastikote.com/plastikot...t;/a>&ProductName=Engine%20Enamel
Color page:
Hope that helps.
Jeff
I know that you guys already your paint issues solved, but keep this in mind for future reference. I work for a company called Finishmaster. We handle body and paint supplies, and also mix pretty much all of the paint that we sell. We sell Dupont, Nason, Spies Hecker, Centari... It's a coporate company, and we have a bunch of stores all over the country. You can either bring in a paint code and we can cross reference it over, or, this is the wonderful part, bring a part with the paint on it that you'd like to match. As long as it's a flat surface, we can take a picture of it with this handy little camera, plug it in, and either find an existing match to the color, or make a new formula for it. Our website is www.finishmaster.com. I hope that this helps some of you guys out.
~Jenny
"Custom can't be bought. It's achieved one cut at a time."
1950 Chevrolet 3100 1/2-Ton
