0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#331054 10/31/2007 4:06 PM
my 46 2 ton has a ms 420 trans with the drive shaft parking brake
i would like to put a duel master and booster frame mounted the
parking brake leaves little room if someone has done this i could use a little help and a picture would be great. philip
I have a 56 6100 that I add a hydro-boost to in the same manner the hydro-boost dose not require the room of the vacuum booster however you must ad a power steering pump to provide the power.
Another option may be to add the new duel master cylinder and one more identical hydro-booster to the outside of the frame use two like the one you have now and plumb one to the front and one to the rear. Many of the late sixties early seventies hydraulic brake systems where done like that.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
