| | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | my 46 2 ton has a ms 420 trans with the drive shaft parking brake i would like to put a duel master and booster frame mounted the parking brake leaves little room if someone has done this i could use a little help and a picture would be great. philip | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I have a 56 6100 that I add a hydro-boost to in the same manner the hydro-boost dose not require the room of the vacuum booster however you must ad a power steering pump to provide the power. Another option may be to add the new duel master cylinder and one more identical hydro-booster to the outside of the frame use two like the one you have now and plumb one to the front and one to the rear. Many of the late sixties early seventies hydraulic brake systems where done like that. | | |
