8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Hello all, I was wondering where I should install the rear shocks mounting bar, how far from the rear end it should be?
Thanks James
If it was easy, everybody would be doing it.
| | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Somebody out there has had to install a shock mounting bar, cross member for the rear end of a truck. I am just looking for some ideas.
Thanks James
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What year and size truck are you installing it on? Most older GMs (pre-73 w/staggared shocks) the upper shock mounts are placed just aft of the axle centerline, basicly flush to the axle housing cover face. Shocks themselves are mounted at an approximate 45 degree angle from verticle, with the uppers pointed inboard.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | The truck is a 41 3/4 ton long bed, I have a GM 10 bolt rear end.
| | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | What is the difference between the shocks at 45 degrees from vertical & straight up & down like Big Chevy's? and what is the diameter of that rear shocks mounting bar Big Chevy?
Thanks James
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | James: the bar is 1.75 soft steel and the shocks are at 80 degrees. You just don't want them to be at 90 degrees. You have to plan ahead as to how you will route your exhaust pipes. Be sure to leave yourself enough room to get back through there.
~Jim
| | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Thanks again Big Chevy
James
