8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln), 78 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#3305 09/29/2004 2:00 PM
Junior Member
Junior Member
I have to much play in my steering wheel hopeing to be able to adjust without rebuilding if I can it is manual steering what is proper way to take up slack almost 1/4 turn free play any help appreciated manual steering c30
Thanks Dave
#3306 09/29/2004 10:30 PM
Riding in the Passing Lane
1st check to see if the play is in the steering
gear or the linkage. Watch the end of the pitman
arm where it goes to the drag link. Check for play
in the shaft that hooks to the steering colmn. If
there is play in it loosen the lock ring & screw
the bearing nut down a little to remove the play.
Tighten the lock ring. With the wheesls straight
ahead loosen the nut in back of the sector shaft.
(5/8 wrench). Turn the screw in till it bottms &
back it out 1/4 turn. Turn wheels side to side &
check for binding. This might get you by but you
probably need a rebuild. smile
1972 Chevy c10 Cheyenne Super
#3307 09/29/2004 11:45 PM
H Online: Content
Here's the way we did it in a professional front end shop for a lot of years. It's a little tedious, but it's very accurate. Start by disconnecting the steering gear from the rest of the system by removing the Pitman arm, or otherwise isolating the steering gear. Count the number of turns of the steering wheel lock-to-lock, and turn it back halfway. This should be very close to the "center point", the area of minimum clearance between the worm and sector gear. Adapt an inch-pound torque wrench to the center nut on the steering wheel. (This usually involves enough socket adapters to allow a 1/4" drive torque wrench to turn a nut about 7/8" in size.) Using the torque wrench, start turning the wheel about 1/2 turn from the center point, and turn it through center, watching the torque reading. It should rise about 10 inch pounds as the gear moves across center. For instance, if it takes 10 in/lbs to move the wheel when it's off center, it should rise to 20 in/lbs as it goes over center, and drop to 10 again after it passes the center point. If it rises, drops at the center, rises again, and then drops, the worm gear is worn out and the gear needs replacing. The preload is changed by tightening the sector gear adjustment, and locking it in place with the locknut when the preload is correct. The wheels should be adjusted to point straight forward when the steering gear is on the center point. This can be done by using a string stretched from front to rear wheels, and connecting the steering linkage when the wheels are pointing straight ahead, and the gear is center-pointed. Lots of work, but worth it!
#3308 09/30/2004 3:12 AM
Junior Member
Junior Member
I am new to this stuff and don't know how to adjust the steering box.But I do have a spare I too out of my 66 GMC burb.That worked great and would be alot easer.I'm putting power on mine.get in touch with me.hope this will help smile
"Life Is all about [censored]! Your either covering it, laughing it off, kicking it, kissing it, busting it, or trying to get a piece of it. Have a good day!!"
