1st check to see if the play is in the steering
gear or the linkage. Watch the end of the pitman
arm where it goes to the drag link. Check for play
in the shaft that hooks to the steering colmn. If
there is play in it loosen the lock ring & screw
the bearing nut down a little to remove the play.
Tighten the lock ring. With the wheesls straight
ahead loosen the nut in back of the sector shaft.
(5/8 wrench). Turn the screw in till it bottms &
back it out 1/4 turn. Turn wheels side to side &
check for binding. This might get you by but you
probably need a rebuild.
