8 members (FAST55, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf, 55shaker, Ponchogl), 75 guests, and 4 robots.
Topics128,065
Posts1,055,868
Members48,428
#330454 10/30/2007 11:24 AM
I'm getting ready to sand blast the frame on my 6400 this week. I mentioned in past threads that the end of the frame is bent outward on the passager side where the front bumper attaches. Last night I put the bumper on the truck to take some measurements and noticed the bumper is caved in about a 1/2". It looks like the truck may have hit a tree at one time at the spot where the bumper attaches to that side of the frame. These big bumpers are thick as h**l and was wondering if anyone has some ideas or suggestions as to how to push it back out. It's not that bad and if I didn't mention it, you'd prolly wouldn't see it.
I was thinking about using the butt end of a 2x4 and shape to the contour of the bumper, lay it on a sand bag, then wack it with a sledge. What do ya think?
Yes a sledge would work. frown I clamped mine to a bench and used a hydraulic jack or in my case a port-a-power. wink That place on the frame was so bad on my truck I cut it off and welded a new one on from a parts truck. smile
I have used a log splitter as a press to straighten bumpers, using a large section of channel on the wedge-worked really well, it also breaks down tires **poster not responsible for loss of fingers,do not try this at home, for novelty use only**
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Apprentice
Apprentice
I've seen my grandfather do quite a bit of body and frame work with a tree and a come-along. You'd need a pretty big one for these trucks though.
I had to pull push and prod at both the one on my 56 and the 64 with chains and my excavator.
Same disclaimer as 64fleetside
**poster not responsible for loss of fingers, do not try this at home, for novelty use only** wink Also not responsible for unintentional bumper removal grin
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Chain and a 4wheel drive. grin
Keith
If it were easy they'd have grade schoolers doing it!
