3 members (Otto Skorzeny, 1955 1 Series, Wheelie), 165 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#33073 06/21/2002 1:08 PM
Apprentice
Apprentice
Do the bolts holding the intake and exhaust manifolds on need to be at a certain torque on a 1957 235 engine? If so, does anyone know what the torque specs are?
Yes, they are supposed to be torqued. My shop manual is at home, I highly recommend you get one if you haven't already. The reality is that you can't get a socket on some of the bolts without a u-joint, therefor the torque wrench doesn't help.
Fred
52 3600
69 C-10
Anonymous
Unregistered
Anonymous
Unregistered
Per shop manual section 6-48. Manifold center clamps 15-20 ft.lbs. Manifold end clamps 25-30 ft.lbs.
One more trick that I do on these engines. When install the manifolds, put a bead of Ultra copper RTV on the manifold side of the gasket. They tend to warp and don't seal very well. Let the engine sit for 24 hours before starting to allow the sealant to cure.
Fred
52 3600
69 C-10
Anonymous
Unregistered
Anonymous
Unregistered
Fred T is correct on the RTV. & Dont forget to use the intake to head rings.
Socket Breaker
Socket Breaker
Neat-O, my Pop started posting up here at last.
Melvin, that's him...
So the same truck he is asking questions about is the same truck I have been pestering ya'll about. smile
tinker tinker tinker
before ya know it we may have it running again.
smile
