2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 17 Apprentice | | Apprentice Joined: Feb 2006 Posts: 17 | Does anyone know if there's an adapter that would allow me to bolt a 1970's 250 (out of a Nova) to the bell housing of a 1946 216? If so, where can I get one?
I'm trying to put a 250 into my 1946 3800 (1 ton). I've got a good 250 out of a 70's Nova. The '46 is running a rattley 1956 235 right now. I know I could rebuild the 235, but I'd like to have the durability of the newer 250.
Thanks, Carolyn
ct5philos
1955 Chevy Cameo 1946 Chevy 3800 stakebed 1949 Studebaker 2R5 1953 Ford Mainline 1962 Studebaker GT Hawk 1962 Studebaker Daytona
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | There is no such adapter. You will have to make new side motor mounts for the 250, new mounts for a more modern trans etc etc, LOTS OF WORK! It can be done if that's what you really want, much simpler to rebuild that 235. | | | | | Joined: Aug 2003 Posts: 37 New Guy | | New Guy Joined: Aug 2003 Posts: 37 | A v8 belhousing from a late '50s or early '60s truck will bolt up to the 250. It will not be a bolt up to the '46 crossmember. However if you can do a little fabrication you can probably make it work.
I bolted a v8 into a '48 pickup with that bellhousing by using a '54 crossmember. I don't know how close a '54 crossmember would be to what you have now.
Of course you would have to build side motor mounts for the front. I agree, rebuilding the 235 would be easier. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There was a transmission change in '48 and if I remember correctly the earlier one does not fit a later transmission. That would create a challenge in your situation.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
