| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32956 06/19/2003 9:35 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Hi.....got a 59 w/235 ....oil leaking out of hollow stud that holds one side of the fuel pump on...it looks like it needs a vaccum hose to somewhere....Can someone clue me in what his is for and is it needed....Thanks, Alan
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#32957 06/19/2003 9:41 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | acwhite welcome to the board! Well I am not sure if you have a combo fuel/ vacuum pump but what ever you have should not be leaking oil. I think no matter which pump you have you will want to replace it. just my opinion and it is worth what I charge for it.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#32958 06/19/2003 11:00 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Thanks Brian.......the stud is hollow and has a fitting for a hose..I put a piece of vaccum hose on it and used the old screw a bolt into it trick to stop it up for the time being..Just got the truck and its bleeding to death...Trying to get some oil leaks stopped...Have done all the easy ones..lifter side plate,valve cover,fuel pump...now its time for the oilpan etc...Thanks again
#32959 06/20/2003 1:02 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That's a strange thing, my fuel pump is held on with two bolts. Can you post a picture?
#32960 06/20/2003 3:48 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 235 fuel pump should have two bolts throught the flanges that are solid. If someone put a hollow bolt in one of these, something's wrong. If you have the combo pump with fuel pump on top and vacuum pump on the bottom, there will be two vacuum lines on the bottom. But since your truck should have electric wipers (I think) you wouldn't need a vacuum pump.
Fred 52 3600 69 C-10
#32961 06/21/2003 3:57 AM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Thanks Guys.....I will replace that hollow stud with a bolt...Alan
#32962 06/22/2003 2:02 AM | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | now hold on.... I have the same thing on my 59 235. There's a small hose that goes to one of the vacuum fittings on the fuel pump, from the hollow stud. Darned if I know why..... | | |
#32963 06/23/2003 2:02 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | acwhite my applogies for not reading your post right. Thanks guy for catching that.
#32964 06/23/2003 3:26 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by vtapache: now hold on.... I have the same thing on my 59 235. There's a small hose that goes to one of the vacuum fittings on the fuel pump, from the hollow stud. Darned if I know why..... That's a new one on me! wonder if it's for lube to the pump or some sort of pollution device.
#32965 08/16/2005 10:59 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Still would like to know more about this hollow bolt on the right side of my fuel pump...It does mention it as a crossover in the shop manual...Thats all I have found so far though.
