4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#32956 06/19/2003 9:35 PM
Hi.....got a 59 w/235 ....oil leaking out of hollow stud that holds one side of the fuel pump on...it looks like it needs a vaccum hose to somewhere....Can someone clue me in what his is for and is it needed....Thanks, Alan
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#32957 06/19/2003 9:41 PM
acwhite welcome to the board! Well I am not sure if you have a combo fuel/ vacuum pump but what ever you have should not be leaking oil. I think no matter which pump you have you will want to replace it. just my opinion and it is worth what I charge for it.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#32958 06/19/2003 11:00 PM
Thanks Brian.......the stud is hollow and has a fitting for a hose..I put a piece of vaccum hose on it and used the old screw a bolt into it trick to stop it up for the time being..Just got the truck and its bleeding to death...Trying to get some oil leaks stopped...Have done all the easy ones..lifter side plate,valve cover,fuel pump...now its time for the oilpan etc...Thanks again
#32959 06/20/2003 1:02 AM
That's a strange thing, my fuel pump is held on with two bolts. Can you post a picture?
Paint & Body Shop moderator
#32960 06/20/2003 3:48 PM
235 fuel pump should have two bolts throught the flanges that are solid. If someone put a hollow bolt in one of these, something's wrong. If you have the combo pump with fuel pump on top and vacuum pump on the bottom, there will be two vacuum lines on the bottom. But since your truck should have electric wipers (I think) you wouldn't need a vacuum pump.
Fred
52 3600
69 C-10
#32961 06/21/2003 3:57 AM
Thanks Guys.....I will replace that hollow stud with a bolt...Alan
#32962 06/22/2003 2:02 AM
V
V Offline
now hold on....
I have the same thing on my 59 235.
There's a small hose that goes to one of the vacuum fittings on the fuel pump, from the hollow stud. Darned if I know why.....
1959 3200 Apache Fleetside
In the Legacy Gallery
#32963 06/23/2003 2:02 PM
acwhite my applogies for not reading your post right. Thanks guy for catching that.
Brian Moore
#32964 06/23/2003 3:26 PM
Quote
Originally posted by vtapache:
now hold on....
That's a new one on me! wonder if it's for lube to the pump or some sort of pollution device.
Fred
52 3600
69 C-10
#32965 08/16/2005 10:59 PM
Still would like to know more about this hollow bolt on the right side of my fuel pump...It does mention it as a crossover in the shop manual...Thats all I have found so far though.
