2 members (46 Texaco, 3B), 93 guests, and 6 robots.
Topics128,185
Posts1,057,275
Members48,467
Apprentice
Apprentice
Does anyone know if there's an adapter that would allow me to bolt a 1970's 250 (out of a Nova) to the bell housing of a 1946 216? If so, where can I get one?
I'm trying to put a 250 into my 1946 3800 (1 ton). I've got a good 250 out of a 70's Nova. The '46 is running a rattley 1956 235 right now. I know I could rebuild the 235, but I'd like to have the durability of the newer 250.
Thanks, Carolyn
ct5philos
1955 Chevy Cameo
1946 Chevy 3800 stakebed
1949 Studebaker 2R5
1953 Ford Mainline
1962 Studebaker GT Hawk
1962 Studebaker Daytona
There is no such adapter. You will have to make new side motor mounts for the 250, new mounts for a more modern trans etc etc, LOTS OF WORK!
It can be done if that's what you really want, much simpler to rebuild that 235.
1946 1/2-Ton Chevy
A v8 belhousing from a late '50s or early '60s truck will bolt up to the 250. It will not be a bolt up to the '46 crossmember. However if you can do a little fabrication you can probably make it work.
I bolted a v8 into a '48 pickup with that bellhousing by using a '54 crossmember. I don't know how close a '54 crossmember would be to what you have now.
Of course you would have to build side motor mounts for the front. I agree, rebuilding the 235 would be easier.
There was a transmission change in '48 and if I remember correctly the earlier one does not fit a later transmission. That would create a challenge in your situation.
