6 members (Otto Skorzeny, walter74, 55shaker, Ponchogl, cmayna, Shade Baby), 212 guests, and 2 robots.
Topics128,114
Posts1,056,282
Members48,439
#328103 10/17/2007 4:06 PM
Here's a few pics of one of my door repairs, patch panel, rust repair and interior paint. Hope this link works! This link has the pics, don't be fooled by the double rainbow shot, it's at the beginning of the album! [img]http://thumb15.webshots.net/t/60/460/3/89/32/2618389320100057575yRbqUa_th.jpg[/img]
Mike
#328104 10/18/2007 1:53 AM
I'm curious to know what method you used to repair the rust on the lower part of the door.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
#328105 10/18/2007 2:30 PM
For the rust out on the outer door surface, the holes shown, I cleaned the inside surface and put down two layers of fiberglass (let one layer harden, then put on another layer.) Then on the outside surface, since there was a "gap" between the fiberglass on the inside, and the surface area of the door, I put some 'glass in the "hole" to build up the void area, then used bodyfill (Dolphin brand by UPOL) to smooth over the area, then sanded it down smooth.
Not sure if this method would be acceptable by some bodyshop guys, but seemed to work out good for me.
The inner panel rust at the bottom, I got the patch panels from Jim Carter, and weld them in place, ground the welds down, and then a light coat of body fill, sand, and then primer. Really my first attempt at welding, came out nice for a "driver" truck.
Mike
#328106 10/18/2007 2:34 PM
I also used fiberglass to repair the rusted out area on my bed (one side only) just below the angle strip, and under the wooden floor. On the inside, I put a layer of 'glass over the rust line, after cleaning out the rusted metal, and used body fill over the outside area. Came out good, and not noticeable.
Mike
