5 members (Phak1, Greg_H, GMCJammer51, WICruiser, dt235sd), 53 guests, and 0 robots.
Topics128,196
Posts1,057,395
Members48,471
Junior Member
Junior Member
I put new rubber on the inside top edge of the doors and door panels where the door glass goes down and up but the rubber wants to roll down when the window is rolled down, the rubber stays in the locking channel but shouldn't the rubber stay in place against the glass?????????? 1942 wave
Z
Z Offline
Mine did the very same thing. I ended up removing one side on the drivers and will do the same on the passenger. It makes it very hard to roll the window up as well. I am with you and thought it should work with nor problems. I even thought may the rubber piece was just too long.
1946 Chevy Pickip
Zipper thats a nice truck ,but
Popa Kents Body Shop
Z
Z Offline
Quote
but what?!?!
1946 Chevy Pickip
Hi guys,
I have not installed my wipers yet, Where did you get your rubber? I got mine from Jim Carter. Hope I do not have the same problem. When I compared it with the original it looked correct.
Harold
Harold
