0 members (),
126
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 16 Junior Member | | Junior Member Joined: Apr 2002 Posts: 16 | I put new rubber on the inside top edge of the doors and door panels where the door glass goes down and up but the rubber wants to roll down when the window is rolled down, the rubber stays in the locking channel but shouldn't the rubber stay in place against the glass?????????? 1942  | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Mine did the very same thing. I ended up removing one side on the drivers and will do the same on the passenger. It makes it very hard to roll the window up as well. I am with you and thought it should work with nor problems. I even thought may the rubber piece was just too long.
1946 Chevy Pickip
| | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | Zipper thats a nice truck ,but
Popa Kents Body Shop
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Originally posted by popa: Zipper thats a nice truck ,but but what?!?!
1946 Chevy Pickip
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Hi guys, I have not installed my wipers yet, Where did you get your rubber? I got mine from Jim Carter. Hope I do not have the same problem. When I compared it with the original it looked correct. Thanks, Harold
Harold Is a restoration ever finished? | | |
