6 members (Gdads51, tclederman, Otto Skorzeny, Jon G, TexasA&M48Truck, Tom McGrath), 96 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
#327929 07/29/2007 4:34 PM
Apprentice
Apprentice
Hi bolters
Need some wisdom to remove a smoked almost black film applied by previous owner to my GMC 59 rear window. Large window version. I wouldnt like to try with a knife. Is it there any other way to avoid scratching my windows?. Any help will be very much appreciated.
Chevy'51
GMC '54
GMC '56
GMC '59
#327930 07/29/2007 5:35 PM
razor blade scraper?
followed by solvent and 000 steel wool to get the glue off....
GMC: Get More Cash...
1958 GMC
My Webshots photos
#327931 07/30/2007 6:29 AM
I have the same problem to deal with on my 52 ...it has an aftermarket slider with some real crappy type of window tint ..I am gonna try to soften the film with Acetone an then go after it with a razor scraper and then clean up the glue with Acetone or Paint Thinner ..?
1952 Chevy Shortbed
Photos in Photobucket
#327932 07/30/2007 6:33 AM
try a heat gun or hair dryer, warm it up and slice it off with a razor blade - softening the stickum should make it come off cleaner
#327933 07/30/2007 7:18 AM
Thanks Bill ...i Just remebered my heat gun for for RC Aircraft projects !
THAT SUCKER WILL WARM IT UP !
1952 Chevy Shortbed
#327934 07/30/2007 11:38 PM
I have heated old crap tint & peeled off with a razor blade. You will still have a lot of glue to clean up but it will come off with some ebow grease.Do it in an area with lots of fresh air. The ones I have done the old glue stinks pretty badly, but will go away in no time.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#327935 07/31/2007 2:55 PM
Thanks for the Tip Alan
1952 Chevy Shortbed
#327936 08/03/2007 9:22 PM
a razer blade an some goo gone or what ever u call it
LEWIS
I don't know what they used for the old tint, but when I got the tint done on my daily driver, the guy said not to use ammonia-based window cleaner on it, as it is what pros use to remove old tint. I've not used it, so I can't say for sure, but if he's right, just try some ammonia, might just take it right off.
Like Alan said, though: Do it in the fresh air, don't want any casualties :P
[EDIT] Sorry to bring up an old post, forgot to read the date dang
Wide open 'til you see God...
Then brake
'64 Stepside 355, 700R4, 10:1 C/R, TCI Streetfighter, Thumper Cam, Hedman Hedders, starting wiring and bodywork shortly, W.I.P.
'07 Charger 3.5L
'99 Dodge Ram 1500 Ext. Cab 360 4x4 (Sold)
'07 F@#$ Focus ST (Sold)
the film should pull off if you can get a corner started with a razor blade and i have used windshield washer fluid in a squirt bottle on the glue. spray on let it sit a couple minutes and use the razor blade to scrape it off, cleans off paint overspray too!
razor blade and windex, works like a charm
The hot air gun technique works pretty well (just don't melt your seals! dang) and a good fresh razor blade.
As the other guys have said,decent glass cleaner and razor takes care of any residue.
As Alan said the old gum stinks! big_eek
More pix on Flickr.
