7 members (Peggy M, walter74, moparguy, NJC, HandyAndy, Oswald, 1 invisible),
137
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I posted this question in the autobody and paint forum before I read further down on the list  I just finished replacing the door latch's/controls, striker plates & handles,on my 51 and everything looks and opperates great But when you push the inside handle on the drivers side to lock it... It opens the door ! I cant figure out how to make it lock it opens both ways did I do something wrong ? :confused: Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Tabdoo, you have to turn the actuator arm upside down from where it is now,,or perhaps you have the pass. side and driv. side crossed up? The part that screws to your door,where the handle fits on,,unscrew it,flip it upside down from where it is now,screw it back on. then re-position your door handle. Did this make sense? Hope so. | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Delux54panel You were right ! I had crossed up the two, The driver's door still wont lock "it go's into the lock position from the inside but you can open it from the outside" But the pass.side is working great now Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Hmmmm,,I guess at this point is just try all the above mentioned things on the driver door,,it worked on the pass. door, or maybe try working the door latch by hand from the inside,,without the handle and long arm hooked up. These things get kinda tricky sometimes with pivot points and pulling,pushing,etc..... Good Luck, Marty | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I'll keep trying Thanks Marty Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
