2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
when shutting my drivers door i have to reopen and shut it again like 5 times to get it to at least lock shut. it doesnt even look completely shut for some reason. do i need to replace the latch mechanism or what? any advice is appreciated. thanks in advance.
Z
Z Offline
push the door almost closed and see if the body lines line up,if not the hinges need adjusting.if the lines line up the latch needs adjusting.you did try greasing the latch,didn't you?
no the body lines dont match, i guess i will adjust the hinges, but i guess i should grease the latch first haha.
