2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | when shutting my drivers door i have to reopen and shut it again like 5 times to get it to at least lock shut. it doesnt even look completely shut for some reason. do i need to replace the latch mechanism or what? any advice is appreciated. thanks in advance. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | push the door almost closed and see if the body lines line up,if not the hinges need adjusting.if the lines line up the latch needs adjusting.you did try greasing the latch,didn't you? | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | no the body lines dont match, i guess i will adjust the hinges, but i guess i should grease the latch first haha. | | |
