1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Junior Member
Junior Member
I would imagine others have run into this problem.
66 step-side. I have to "lift up" on the door to get it to close smoothly.
I am wondering if the pins on the hinges are worn from years of opening and closing.
Just wondering how I should attack this issue.
Would love to have smooth opening and closing doors!
Thanks for any advise.
From any one of the vendors that cater to the 60 - 66 trucks, order a set of hinge pins and bushings. They'll fix that sagging door right up. They will be a little tough to get apart but not a problem to reassemble,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Z
Z Offline
sometimes you can move the top hinge forward or the bottom hinge rearward to compensate for the hinge wear.it worked great on my 84 camaro.
I worked in the body shop at a Chevy dealership in the 1970's & 80's and used to replace hinge pin/bushings all the time. Not a big job and the bushings are not expensive. Well worth the money for the improvement. If let go too long, the next thing to go will be the door lock & striker.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
