Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (msmall, TUTS 59), 45 guests, and 1 robot.
Topics128,009
Posts1,055,296
Members48,419
#327676 01/18/2007 1:26 AM
I have a '59 Apache panel. I had a bad bottom door hinge on the passenger side. In taking it apart, I removed the door and both upper and lower hinges. This was partially for clean-up and primer while I had it apart. The upper hinge had a bolt in the back (foreward most)part of the hinge. When I removed the bolt, there was a square nut on the backside that fell down on to the floor. My problem is that I can't get the nut back up there to put the bolt back in. I can't get to it from the bottom where it fell out and I can't get to it from under the hood. My arm is too big to reach back there. Do I have to remove the fender in order to get to the back side of the bolt? I think I must be missing something? Thanks....
Toxictiki
'59 Apache 3100 panel (235)
'51 Chevy Fleetline Deluxe (216)
'48 Binder KB-1 (flathead 6)
'77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
#327677 01/18/2007 5:43 PM
how about one of those extendable magnet things?
#327678 01/19/2007 4:36 AM
That might work. I'm still scratching my head on it. Thanks.
Toxictiki
#327679 01/19/2007 5:10 AM
that bolt is a pain!!! you hafta take the fender off to get at where it goes, no choice except leaving it off frown
#327680 01/25/2007 7:44 AM
red58 - thanks for your reply. I had kind of resigned myself to taking the fender off. I was hoping I wouldn't have too, but that's what it looks like. I think I will tack weld the square nut on the back once I can get to it. I think it probably needs the nut and bolt in there because it supports the hinge/door. I guess if I take the fender off, I can really clean it up and paint both sides of it.
Toxictiki
#327681 01/25/2007 8:14 AM
yes, and you'll be able to clean and finish the plenum chamber under there and the back off those hinge pockets, which take a lot a guff at the back of the fender ... that area is always messy on the TF trucks
