6 members (DadsFirstPickup, 49Chief, Otto Skorzeny, D B Cooper, cmayna, 1 invisible), 93 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
Hi Guys: I'm having some difficulties trying to get the window crank off the driver side regulator shaft. Unlike the passenger side window which has a clip hold the crank in place the drivers side appears to not have a clip in place. I suspect the previous owner to this truck may have bonded the crank to the regulator shaft I can't see why it won't budge. Short of using a gear puller and probably destrying the crank in the process I'm not sure how to get it off. Any suggestions?
It may have an older handle that's held on with a set screw. It's usually hidden behind the crank arm. You'll need a long skinny flat screw driver to loosen the screw if this is the case,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Scott: I've been in to have a close look with a flash light and inspection mirror and the crank has groves cut into it for the clip, It's just missing and there is no screw to speak of.
Don
