7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Hi Guys: I'm having some difficulties trying to get the window crank off the driver side regulator shaft. Unlike the passenger side window which has a clip hold the crank in place the drivers side appears to not have a clip in place. I suspect the previous owner to this truck may have bonded the crank to the regulator shaft I can't see why it won't budge. Short of using a gear puller and probably destrying the crank in the process I'm not sure how to get it off. Any suggestions? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It may have an older handle that's held on with a set screw. It's usually hidden behind the crank arm. You'll need a long skinny flat screw driver to loosen the screw if this is the case, Scott | | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Scott: I've been in to have a close look with a flash light and inspection mirror and the crank has groves cut into it for the clip, It's just missing and there is no screw to speak of. Thanks Don | | |
