1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#327537 08/25/2006 2:06 AM
I'm getting ready to rebuild the hinges on the driver door of my 51 3100, and of course the pins are rusted into the hinge. What is the best way of removing the pins? I saw in a previous post someone recommended to heat the hinge, and pound the pin out. How hot do you get the hinge? Is a soldering torch hot enough? Do you try to hammer the pin out while it is hot, or does the heating and cooling loosen it?
Thanks for any help
#327538 08/26/2006 1:38 PM
a small propane torch willnot do it,,you will have to heat it to dull orange and remove pins while hot...doc
#327539 08/26/2006 5:33 PM
Thanks, doc. I'll have to find someone with a real torch and a big hammer! I guess a thick pair of gloves would come in handy also.
#327540 09/02/2006 8:13 AM
I found that the only way my 54's hinge pins would come out was with a torch and a 5 ton press. They can be REALLY stubborn. A shop with a press will be a good thing to locate.
Good luck.
1956 GMC 100 NAPCO Deluxe
1955.1 Chevy 3600 NAPCO
1954 Chevy 3600 NAPCO
#327541 09/03/2006 3:09 AM
My front ones are fine. Its the rear ones on my panel that are frozen tighter than a bango string. Just today I tried to press them out but they didn't want to budge without possibly messing them up. So, they must be "torched". I spent all day on ONE hinge beating and pounding, kroil, beat pound...beat pound. Honestly, it better to find someone with a torch to get it HOT and then they will come out nice and smooth! I'm sending mine with my nephew to Freightliner so he can torch them out while I drink Pepsi! Save the frustration and foul words....use a torch.
#327542 09/04/2006 3:26 PM
I was able to drill mine out and then use a hammer and punch
#327543 09/10/2006 5:54 AM
1 Offline
folks,here is a way that you can get those stuck pins out: mapp gas and bee's wax! you can get mapp gas at home depot and bee's wax at craft store's in candle form.for some reason bee's wax has a "wicking" effect.i use it on frozen pinion drives that are in the food processing machines i service. found out about it when i was working for a major engine rebuilder back in the 80's. at the time we were tearing down 140 motors a day and the guys pulling out crankshafts used it for frozen main cap and rod bolts.check it out. good luck
#327544 09/12/2006 4:18 AM
my nephew torch them some and he said the pins practically fell out. I didn't even have to light the torch. wow, that was easy!!
