8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | how much adjustment is there or should there be on 53 rear barn doors. i have 1/4" at top between doors maybe a little more than 3/8" at bottom between between the two doors. d.s. door gap looks fine around body lines. p.s. looks correct at top side, but has 1/32"at bottom body side.the hinge mount look like 1/32" in any direction adjustment may be possible. i guess drillin grinding bfg might be the necessary correction. any thoughts? thanks tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | When I lined up the doors on my panel I was having a very difficult time. There was no way to do it. My gaps were way out all over the place. After lots of looking and measuring I discovered that the van was bent over to the drivers side on top. Like I'm talking the whole body was crooked. I had to take it to a body shop and put it on a frame straighting machine and have them hook on near the top of the rear door and give it a pull back to the passenger side. After that the doors fit perfactly.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | There is no "easy" adjustments, as on side doors (and, adjusting them seems a feat of magic).
highwayman has the answer. And, do it with all parts in place, ready to paint, but before painting. | | |
