| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 3 Junior Member | | Junior Member Joined: Mar 2006 Posts: 3 | I have a 1965 Chevy I am restoring and need to change the locks. I have bought a lock kit that has matching locks for both doors, the glove box and the ignition.
However, to get into the door to change the door handle locks, I need to remove the metal panel to gain access. The door handle and the window crank handle need to be removed and I cannot see the retaining clip on the shaft. Do these handles require a special tool to remove them or is there a "super-secret" method I can use to get these off without damaging the door or the handles?
Thanks in advance for any assistance. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | you need a flathead screwdriver to loosen the set screw. brian | | | | | Joined: Mar 2006 Posts: 3 Junior Member | | Junior Member Joined: Mar 2006 Posts: 3 | Wow! What a quick response. Thanks 64fleetside. I did a quick visual inspection of the handles (granted I'm an old f**t and it was dark), but I didn't see any set screws. Where are these located? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | they are kinda hidden behind the "arm" part of the handle. brian | | |
