10 members (1955 1 Series, Otto Skorzeny, JW51, Greg_H, Bill Hanlon, Ponchogl, Gdads51, Peggy M, TrknGMC, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,689
#327404 03/23/2006 3:20 PM
Junior Member
Junior Member
I have a 1965 Chevy I am restoring and need to change the locks. I have bought a lock kit that has matching locks for both doors, the glove box and the ignition.
However, to get into the door to change the door handle locks, I need to remove the metal panel to gain access. The door handle and the window crank handle need to be removed and I cannot see the retaining clip on the shaft. Do these handles require a special tool to remove them or is there a "super-secret" method I can use to get these off without damaging the door or the handles?
Thanks in advance for any assistance.
you need a flathead screwdriver to loosen the set screw. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Junior Member
Junior Member
Wow! What a quick response. Thanks 64fleetside. I did a quick visual inspection of the handles (granted I'm an old f**t and it was dark), but I didn't see any set screws. Where are these located?
they are kinda hidden behind the "arm" part of the handle. brian
