Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (TexasFarmTruck, Mike1933), 189 guests, and 7 robots.
Topics128,282
Posts1,058,496
Members48,490
#327394 03/19/2006 12:36 AM
Junior Member
Junior Member
I have a (52 up ?) cab using 48 doors. I am having problems with them latching. On The oringal latches the groves that keep the doors from coming open, are worn. So if you lean against them to hard they will open. Have bought some repro from a big name company. You have to slam the doors to make them latch,when they latch. And thats with the new 52 up strickers pushed out all the way. I am experienced in Door alignment as i have been in the paint and body business for over 25 years, but am now retired. I think the latchs I bought are not a good reproduction. The old latchs seamed to work just fine other than they opened on there own if you leaned on them to hard. Any thoughts out there
#327395 03/19/2006 3:49 AM
There are a difference in latches.
Are you still trying to use the 52 strikers that are on the body?
If so that's the problem, their not compatible with the 48 style latches.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#327396 03/19/2006 8:47 PM
Junior Member
Junior Member
OK I knew that, but the 48 latches will not bolt on the 52 cab. As I remember correctly the cabs are not the same in the latch area.
#327397 03/19/2006 10:30 PM
I put bearclaw latches in my 50.
http://cgi.ebay.com/ebaymotors/BEAR...QQitemZ8046874960QQrdZ1QQsspagenameZWDVW
solved all the problems.
#327398 03/19/2006 11:53 PM
Junior Member
Junior Member
Wilber could you send me some pics of your 50 door locks to [email protected]. Interested on how you made them work with the outside and inside handles. Thanks
#327399 03/20/2006 12:20 PM
For pushbuttons:
http://www.chuckthetruck.com/page23.html
Swing handles just need a little different cipher for the outside link, but the logic is the same.
#327400 03/20/2006 9:20 PM
Junior Member
Junior Member
Chuckthetruck I believe I can make this work for swing down handles handle also. Going to take a long look at it. Very informative Web Page. thanks for the reply.
#327401 03/20/2006 9:53 PM
Thanks chuck,
I've got remote control doors!
My inside handles are slightly modified original relays.
