2 members (Peggy M, cmayna),
226
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 5 Junior Member | | Junior Member Joined: Mar 2006 Posts: 5 | I have a (52 up ?) cab using 48 doors. I am having problems with them latching. On The oringal latches the groves that keep the doors from coming open, are worn. So if you lean against them to hard they will open. Have bought some repro from a big name company. You have to slam the doors to make them latch,when they latch. And thats with the new 52 up strickers pushed out all the way. I am experienced in Door alignment as i have been in the paint and body business for over 25 years, but am now retired. I think the latchs I bought are not a good reproduction. The old latchs seamed to work just fine other than they opened on there own if you leaned on them to hard. Any thoughts out there | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | There are a difference in latches. Are you still trying to use the 52 strikers that are on the body? If so that's the problem, their not compatible with the 48 style latches. | | | | | Joined: Mar 2006 Posts: 5 Junior Member | | Junior Member Joined: Mar 2006 Posts: 5 | OK I knew that, but the 48 latches will not bolt on the 52 cab. As I remember correctly the cabs are not the same in the latch area. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | | | | | | Joined: Mar 2006 Posts: 5 Junior Member | | Junior Member Joined: Mar 2006 Posts: 5 | Wilber could you send me some pics of your 50 door locks to [email protected]. Interested on how you made them work with the outside and inside handles. Thanks | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | For pushbuttons: http://www.chuckthetruck.com/page23.html Swing handles just need a little different cipher for the outside link, but the logic is the same. | | | | | Joined: Mar 2006 Posts: 5 Junior Member | | Junior Member Joined: Mar 2006 Posts: 5 | Chuckthetruck I believe I can make this work for swing down handles handle also. Going to take a long look at it. Very informative Web Page. thanks for the reply. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Thanks chuck, I've got remote control doors! My inside handles are slightly modified original relays. | | |
