7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy), 136 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#327292 01/14/2006 7:19 PM
anybody know the simple method of removing the hinge pin from door hinges i have tried to press it out and then tried to beat it out with no sucess either way. was thinkin of using some heat next.
I don't suffer from insanity, I enjoy every minute of it!
#327293 01/14/2006 7:38 PM
they are threaded......just kidding. just keep working at it & use kroil!
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#327294 01/14/2006 9:24 PM
Could be that they are quite worn and uneven and hanging up on you. When I changed mine, in some spots they were 1/2 the original thickness...
Larry Bear
55.5 Chevy 3100 Panel
#327295 01/14/2006 10:39 PM
TPYLE,
I am interested in this subject as I have contemplated offering hinge rebuilds to bolters. If you read the articles on hinge repair, the first thing they say is, if the pin does not come out with a moderate effort..STOP.
Cease and desist on all beating and heating! Use a hacksaw and cut the pin in two places to facilitate the removal of the door piece from the post piece.
After you have two separate pieces, you can drive or press the pin out without destroying the entire assembly.
There are several good step by step articles on hinge rebuilding out there...maybe someone can provide a link.
Stuart
#327296 01/14/2006 10:51 PM
well here is the update. after i asked this question , i went and beat the crap out of with a 3lb. hammer after it moved a little bit a ballpeen took it out just fine. believe it or not the pin looks good. on the 53 barn door hinge it has a trim cover to pretty up the hinge that is spot welded in 4 places. once i got that off i laid about 20 1 1/2" passes on the hinge bracket where it was just about rusted through.I ground it down and it looks pretty dang good if i have to say so myself any how thanks for the help!!!!!!!!!!tom
#327297 01/14/2006 11:02 PM
oh btw whoever moved this post here thanks, i furgot this section was here. sorry . will that take the grouchy face gremlin off??it kinda reminds me of my wife when i dont do something she wanted me to do
#327298 01/15/2006 5:04 AM
atomarc, i didn't see your post earlier .what i had going was the barn door hinges on my panel which has been in the weather for years.not exactly the same as a cab door hinge.it took a good solid smack with a blunt/flat tip chisle(not a pointed)to get it going. oh and a 3# hammer wink
