7 members (Goach2, Dave1234, IHPWR, Hotrod Lincoln, TUTS 59, Peggy M, 1 invisible),
73
Mod | | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 7 Junior Member | | Junior Member Joined: Aug 2007 Posts: 7 | I would like to put a radio in my 56 3200 p/u. It would be great if it looks stock but would be mp3 or ipod ready. Any contacts? | | | | | Joined: Jun 2007 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 90 | A stock radio can be outfitted with line-level inputs, which would accommodate an MP3 Player or ipod... that's the way to go if you want the "stock" look... I know there are repro radios made but I don't know if they have any special inputs. | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | You can also try Custom Autosound. They make most of the new radios that the vendors sell. Pretty much the same unit with different face combinations to fit the different vehicles. They come with audio cables that plug into the back and a headphone jack you can stretch over to the glovebox to use an ipod, mp3, etc... | | | | | Joined: Aug 2007 Posts: 8 Junior Member | | Junior Member Joined: Aug 2007 Posts: 8 | I bought a radio from Classic industries (I believe) that fit in the stock opening of my 57 3100. It looks fairly stock until you turn it on. Then it has a green glow. The input cable is a jack similar to your I-pod head phones. I drilled a small hole in the side of the glove box and fed the cable through there. I plug in my I-pod and I have everything from Hank Williams to Aerosmith at my fingertips. I did not want a CD changer but it has inputs for that as well. This way I don't lose any space in my cab or glove box!!
Good Luck & Best Regards,
Panhead | | |
